Ground loop would be the first thing to check for. Start with your CATV/SAT cable connection. If that's not it, then I'd disconnect and reconnect each source to see if any of them stop the humming.
I have a pro audiostereo soundcraftsman amp that has a hum(actually ,more of a buzz) in one of the channels. A signal can get amplified through it,but it's distorted with the buzz that gets louder as you turn the amp up. I figured it may be bad caps too. The other channel is great.
