bill_slenter
- Jan 3, 2003
I've just built my first HTPC, and it works great, but the fans are too loud. At first the PC was WAY too loud, but I went to my local Fry's Electronics and purchased the quietest case and processor fans I could find. Also lined the case with Compusa sound absorbing material. Much better now, but at times still too loud. Maybe it's time to look into water cooling (YIKES). Or perhaps I should sit tight and wait for passive heat pipe technology to go mainstream.
Anyway, I'd appreciate any suggestions/experiences people have with this issue.
My System:
-Athlon 1700XP
-ASUS N78X mobo
-Creative Audigy2 sound card
-Creative Megaworks 550 THX 5.1 speakers
-Geforce2Pro graphics
-Belkin 54g wireless LAN
-Gyration wireless keyboard/mouse
-mini-tower case
-40 GB HDD
-DVD-Rom drive
-480P VGA out to a Zenith C27V22 4:3 HD monitor.
The computer is sitting inside a TV stand/cabinet that has a door, so that helps muffle the sound, but it still gets out the back, which I had to cut a big opening into to allow air circulation.
Also, anyone know why my Zenith shuts off and will not turn back on if my PC is plugged into the RGB port but turned off? PC must be on, or cable disconnected, to turn on the TV. Weird...
My System:
-Athlon 1700XP
-ASUS N78X mobo
-mini-tower case
-40 GB HDD
-DVD-Rom drive
