Jason Pancake
- Apr 1, 2002
Just got done making some homemade pizza with the wife. I'll go ahead and share our recipe. What makes your homemade pizza special? Ours is New York style, thin and floppy.
Heat oven with a baking stone if you have one to 500 degrees.
Dough:
Mix 1 cup tepid water (105 - 120 degrees) + heaping 1/2 tbs. yeast + 1/2 tbs. sugar in small bowl or cup. Let sit for 5 minutes so that there is plenty of foam on the surface.
Meaure 2.5 cups of flour into bowl. Create a "valley" in the center of the flower and pour in the yeast mixture. Gradually pull in the flour around the bowl with a fork until the dough pulls in all of the flour. Take the ball of dough to a floured surface and knead for 10-12 minutes. Sprinkle with flour as necessary. Roll dough into a ball and let rest in a lightly oiled bowl covered with plastic wrap until doubled in size. Punch down and let rise again in the fridge (overnight is best but not necessary).
Take out the dough and separate into two parts with a knife or pastry knife for 2 12-14" pizzas. Push the dough out with your hands and toss if you are bold to the desired size. When you are close to the desired size transfer the crust onto a pizza peel with plenty of cornmeal to keep it from sticking. Top with regular tomato sauce. Shake on garlic powder, dried oregano, basil, salt and pepper. Top with cheese and desired toppings and slide onto baking stone in 500 degree oven for 8-10 minutes.
We are always looking for a good pizza recipe. What is your favorite? Any exotic toppings?
Jason
Dough:
Jason
