help with removing the vestiges of lop.com from my pc (1 Viewer)
John*Jones
well, i was clicking way too fast and opened an .exe that installed everything that comes along with lop.com. i downloaded ad-ware and spybot and they did a fine job of removing most everything from my drive. however, i am still being redirected to lop.com whenever i type an incorrect address in both explorer and mozilla.
any suggestions for how to prevent this?
thanks
john
John_Berger
I despise IE, so I would be happy if you never used it again. ;)
As for Mozilla, I believe (although I could be wrong since I've never run into this problem - this is a shot in the dark, you understand) that it's assuming that if a page isn't found, you must be performing a search.
In Mozilla, check Navigator -> Internet Search and see if lop.com is set as the default search engine.
Again, this is a long shot, but it's all that stands out as a possible cause.
John*Jones
thanks for the quick response. unfortunately it wasn't the default search engine.
btw, i am almost completely weaned from IE and use it rarely :) love the built-in pop-up blocker and tabbed browsing of Mozilla.
John_Berger
The best thing to do? Search your entire "C:Documents and Settings" folder and locate any file that contains "lop.com" in the body of the document. I can just about guarantee that you'll locate the offending file and possibly determine from there how to get rid of it.
John*Jones
Thank you much John. After removing some suspicious files from the registry I did a search in the "C:Documents and Settings" folder and found-->deleted 3 lop.com files. After a reboot my problems appear to have been solved (for now at least :) )
Thanks again!!!
BXR Industries
