I need to get my outdoor speakers hooked up to use the same source as my HT receiver. I have a H/K 525 which has a "multi-room" feature, but requires you to kill your surround back channels to have a 2nd source (multi-room). This is not an option for me, since I love my 7.1 setup.
The way I see it, I have a couple of options and I would like your advice on which route is the best.
1) Use the pre-out front left and pre-out front right as inputs into a stereo receiver powering the outdoor speakers. Will that work? Drawbacks?
2) Use a niles speaker selector. My concern with this approach is the load that puts on the receiver. I have read that having 4 8-ohm speakers (ht front left and right + outdoor speakers) would create a 4-ohm load.... AND that the selector would continue to create that load even when the outdoor speakers are switched off. I do not want the speaker selector to damage my 525, nor do I want it to degrade the sound of the home theater (when the outdoor speakers are turned off)
Let me know what you guys think about these two options.
Thanks for your help!
Brian Cliburn
go noles!
Brian Cliburn
go noles!
