Help with Connecting Amp to SVS 25-31CS+ (1 Viewer)
Luis Cruz
Hey all,
I just bought the Parts Express 500 watt amp for my SVS 25-31CS+ and am trying to figure out how to connect it. Now I just want to be positive before I do this but I suspect I am supposed to cut the tips off so I can get the bare speaker wire to connect to my sub. Hopefully someone can verify this for me.
steve nn
Hi Luis,
What do you mean by tips? You will want to hook it up in the same fashion as a reg speaker. If the tips you speak of are the outer insulation around the wire itself then yes cut the tips off.
ChewyWaffles
