Daniel Swartz
- Mar 3, 2002
Due to the currrent heat wave, I fired up our house's central AC. However, even though everything is running, it won't cool down the house and no water is draining from the unit (as it should). All fittings appear to be iced up.
Is there some place on the web where I can find some basic advice on what to do or what the problem might be before I call a repairman? Thanks.
-Sweltering
-Sweltering
