Joe Greca
- Feb 25, 2001
I've tried figuring this all out myself, using the search a ton of times, but I just ended up confusing myself even more!
Anyway, I need to upgrade, badly. I am only keeping my 32" Sony Wega and my JBL PB10" sub. My currect receiver and speakers are an old Aiwa HTiB... Take a look at my current setup:
Now my questions:
1) What receiver would be good for a room like this? I was thinking Denon 2802 maybe? Would the 6th channel sound good in my setup?
2) Speakers??? This is where I am nearly lost. Since the couch is so close to the surround speakers, am I going to need dipoles? If I need them, I'll get them, but they are quite expensive. I was thinking maybe Mini-Monitors? Take 5.2s? Is there anywhere in New Jersey that I could maybe give the n0rh 4.0s a listen? I'm willing to listen to a lot of differernt suggestions...
3) Oh, also, where can I pick up some Aura Bass Shakers for the couch? I think those would be great since I'm in an apartment.
I really would appreciate any advice you guys can give on my currect situation. If you have been in a similar room, let me know what worked out! I just don't want to put too much or too little in this room. I don't want to match a powerful receiver with weak speakers or powerful speakers with a weak receiver. And I'm very worried about having the surrounds so close and direct... The surrounds I have up now don't really work anymore, so they're not a problem, but new ones might prove to be distracting, right?? Thanks again!
[Edited last by Joe Greca on October 23, 2001 at 05:29 PM]
[Edited last by Joe Greca on October 23, 2001 at 05:30 PM]
Now my questions:
