Peter L
Grip
- Jan 16, 2002
Hi, Recently when I was watching a DVD movie, I notice the image on the screen turned to a yellowish/greenish tint and would switch back to regular color back and forth by itself. At first I suspected the monster component cable that I was using but I switched cables same thing. Then I plugged in my xbox with component video in to test, same yellowish tint. So I 'm fairly certain it's my TV that is the problem. If I use Svideo and composite then everything is normal no problems at all, only component inputs from my TV and no matter which component input I use from my tv it still shows the yellowish / greenish tint.
My question is, what is the exact problem with my tv? and how expensive would it be to fix?
My equipment list:
Sony HDTV KP51HW40 widescreen
Panasonic DVD RP-91 Progressive scan
Denon 3802 Receiver
Polk audio speakers
Xbox component out
Any input would be appreciated.
Peter
My equipment list:
Denon 3802 Receiver
Polk audio speakers
Xbox component out
Peter
