johnBrownsdream
- May 31, 2006
- john brown
Alright sorry if this is in the wrong forum. But I have been recentally been looking at lots of cerwin vega 4 ohm speakers because I like lots of deep bass and I am aware that 4 ohm speakers can hit those lower frequencies. I thought I was crusing right along, I was going to either use my harman kardon avr 65 or sell that and get a sansui 9090 and use that for these for ohm speakers. However I did not realize there were 4 ohm receivers and I was wondering if this was really true? I was also wondering if 4 ohm speakers would blow the aformentioned amps for any reason. I am specifically looking at three sets of speakers to hopefully use with the amps. Please or even need to, look at these specifications and tell me if these amps would blow with these speakers or not. If you need amp specifications just ask and I will post them. I just never even heard that there were 4 ohm and 8 ohm receivers. I only saw it once and that was on some message board. Any information clarifiying all of this will help and please respond aspa I am looking at a few auctions right now. Speaker specifications below:
thanks
matt
Cerwin-Vega RE-38 Features:
Power Handling (RMS): 5 to 400 Watts RMS
Frequency Response: 27Hz-20kHz
Sensitivity (dB): 102 dB dB
Impedance (Ohms): 4 Ohms
Weight (lbs): 90 lbs.
Dimensions (w/h/d): 35.75/18/17.75 in. (width/height/depth)
Description: 15 inch 3-way
cerwin vega rs 30
Here are the specs,3 way bass reflex - 12" Woofer, 4" Mid and 1" Tweeter,
5 watts minimum
250 watts maximum
97 dB [ 1w / 1m ]
4 ohms
and finally the cerwin vega at 15
Description: 15" 3-Way
Frequency Response: 28Hz-28kHz
Power Handling Capacity, Minimum/Maximum: 5/400 Watts
Sensitivity, 1W at 1M: 102dB
Nominal Impedence: 4 OHMS
Distortion, Midband at 96dB/M, THD & IM: 0.4%
Maximum Output Level,Pair at 3M,Full Power: 127dB
thanks
matt
cerwin vega rs 30
5 watts minimum
250 watts maximum
97 dB [ 1w / 1m ]
4 ohms
