David Nolan
- Mar 9, 2002
hello all,
i am looking to sell these Klipsch speakers as i attempt to make the home theater more decor friendly for my wife. the KM-6's have been used for surround duties the past 3 years, so no real workout for them - i just need something smaller. the KT-LCR has performed very well as a center, and in fact only needs to be replaced with one in black instead of medium oak. all 3 speakers have been well cared for and have the original covers, badges, etc. there are no scratches or dents, no pushed in cones, no missing feet. they still look and sound great. i've included links to the Klipsch website which has their pics, and can e-mail actual pics to anyone who asks. the specs are listed below. i would prefer not to ship these (at least the KM-6's) due to their size/weight and the prohibitive cost; however, i will deliver them to anyone in the Memphis area, or they can be picked up. for the KM-6's i'm asking $250 for the pair, and the KT-LCR is $150. email if you have any questions, i'm sure i left something out. thanks
david
[email protected]
KM-6's
http://www.klipsch.com/media/Products/432_large.jpg
FREQUENCY RESPONSE:
34Hz-20kHz±3dB
SENSITIVITY:
98dB @ 1watt/1meter
POWER HANDLING:
100 watts maximum continuous (500 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Bass reflex via front-mounted port
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) polymer dome compression driver tweeter with a 90°x60° Tractrix® Horn and two 10" (25.4cm) ICG cone woofers
TWEETER:
K-85-K 1" (2.54cm) Polymer dome compression driver
HIGH FREQUENCY HORN:
HF CROSSOVER:
1600Hz
WOOFER:
Two K-1023-K 10" (25.4cm) ICG cone
DIMENSIONS:
37.5" (95.3cm) x 12.25" (31.1cm) x 17.5" (20cm)
WEIGHT:
69 lbs. (31.3kg)
ENCLOSURE MATERIAL:
Medium density fiberboard construction (MDF)
FINISHES:
Black vinyl
YEARS BUILT:
1994 - 1997
KT-LCR
http://www.klipsch.com/media/Products/147_large.jpg
FREQUENCY RESPONSE:
65Hz-20kHz±3dB
SENSITIVITY:
95dB @ 1watt/1meter
POWER HANDLING:
100 watts maximum continuous (425 watts peak)
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Sealed
DRIVE COMPONENTS:
Two-way system using one 1" (2.54cm) magnetically shielded, polymer dome compression driver tweeter with a 90°x60° Tractrix® Horn and two 6.5" (16.51cm) magnetically shielded, poly cone woofers
TWEETER:
K-90-KV 1" (2.54cm) Polymer dome compression driver
HF CROSSOVER:
2400Hz
WOOFER:
Two K-1006-KV 6.5" (16.51cm) Poly cones
DIMENSIONS:
23.25" (59.1cm) x 11" (27.9cm) x 10" (25.4cm)
WEIGHT:
31 lbs. (14.1kg)
ENCLOSURE MATERIAL:
FINISHES:
Whitewash, Light Oak, Medium Oak, Cherry, Walnut, Black Satin
YEARS BUILT:
1994 - 1997
david
[email protected]
KM-6's
FREQUENCY RESPONSE:
34Hz-20kHz±3dB
SENSITIVITY:
98dB @ 1watt/1meter
POWER HANDLING:
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
DRIVE COMPONENTS:
TWEETER:
HF CROSSOVER:
1600Hz
WOOFER:
DIMENSIONS:
WEIGHT:
69 lbs. (31.3kg)
ENCLOSURE MATERIAL:
FINISHES:
Black vinyl
YEARS BUILT:
1994 - 1997
KT-LCR
FREQUENCY RESPONSE:
65Hz-20kHz±3dB
SENSITIVITY:
95dB @ 1watt/1meter
POWER HANDLING:
NOMINAL IMPEDANCE:
8 ohms
ENCLOSURE TYPE:
Sealed
DRIVE COMPONENTS:
TWEETER:
HF CROSSOVER:
2400Hz
WOOFER:
DIMENSIONS:
WEIGHT:
31 lbs. (14.1kg)
ENCLOSURE MATERIAL:
FINISHES:
YEARS BUILT:
1994 - 1997
