Jerry Klawiter
- Dec 3, 2000
Hello all,
I'm selling this for a friend.
$130 shipped within the U.S.
I'm a master trader here, paypal is fine.
The remote is used, but in great working order.
NO scratches on the screen.
Includes the original box, users guide, interface cable.
This Pronto is dark blue in color, looks just like the TS2000 models but only dark blue and with 1MB not 2mb.
Sorry image was removed to save bandwidth once sold.
For more info about this particular model including reviews and software downloads, check out: http://www.remotecentral.com/pronto/index.html
Features
Large dynamic touch screen with liquid crystal display
Direct-access buttons for frequently used functions
Elegant, intuitive interface with animation
Automatic backlighting for visibility in the dark
Built-in, customizable device templates for total control
Programmable, editable macros (device or activity based)
Programmable, editable timers
Virtual keyboard for labeling buttons and devices
Can control any device that receives infrared remote control signals
Learns infrared (IR) codes from your existing remote controls - then replaces those remotes
Comes with hundreds of built-in commands (RC-5/6) for out-of-the-box use with your Philips and Marantz components
Software upgrades available via download
Designed for one- or two-handed operation, or tabletop use
Flash memory stores your commands even when batteries aren't present
Pronto Edit, a PC software package, allows you to completely redesign the graphical user interface to meet your needs, You will need to down load the latest.
Pronto Emulator feature allows you to view and test new configurations before downloading
Specifications
Hardware
High-resolution (320 x 240) liquid crystal display (LCD) with contrast control
Large touch screen
Seven programmable direct-access buttons
Backlighting for LCD and direct-access buttons
Built-in RC-5 and RC-6 codes
Infrared sending and learning eyes
3-wire (RS232) serial port connector
Software
Dynamic, animated interface
Editable macros (up to 255 commands per macro)
Total number of devices and macros limited only by memory
Infrared (IR)
Operating distance of 10 meters (33 feet)
Learning frequency up 56 KHz
Learning distance 2,5 cm (1 inch) up to 30 cm (1 foot)
Memory
1 MB non-volatile flash memory (retains commands when batteries are not present)
512 K SRAM
Batteries
4 AA 1.5V batteries, or one 4.8V rechargeable battery pack option
Battery life
Approximately 6 months with typical use
Power management
Power on by tapping the touch screen, power off automatically
Dimensions
138mm x 92mm x 38mm (5.4 inch x 3.6 inch x 1.5 inch)
Operating temperature
0°C to 50°C (32°F to 122°F)
Features
Specifications
Hardware
Large touch screen
Software
Infrared (IR)
Memory
512 K SRAM
Batteries
Battery life
Power management
Dimensions
