For sale a BRAND NEW (Unopened) MDP-100 (MyHD) PC HDTV card. Asking $195.
Here are the specs from their website:
MDP-100 is a digital(ATSC)and analog TV(NTSC) receiving card to utilize a plain Pentium PC as a good HDTV system at a low cost.
Receiving terrestrial digital TV and conventional analog TV programs, MDP-100 can display the programs on an existing PC monitor and/or a high quality HD display monitor.
MDP-100 also supports capture and playback of digital & analog TV broadcasting programs and external A/V inputs.
You can enjoy the functional advantages of digital VCR with your PC because MDP-100 can store digital TV program into a PC file and perform playback with the file.
¡á Main Features
¢º Fully compliant with ATSC digital television standard
¢º Supports analog TV(NTSC) and analog cable broadcasting
¢º Receives 8 VSB terrestrial broadcasting signal and conventional NTSC broadcasting signal
¢º HDTV (MPEG-2 MP@HL) and SDTV(MPEG-2 MP@HL) video decoding
¢º 5.1-channel Dolby Digital audio decoding
¢º Provides external S-Video, composite video and analog stereo audio input
¢º Store and playback of digital & analog TV broadcasting programs and external A/V inputs
¢º Display on a high quality HD display monitor and/or a PC monitor via VIP1.X video port.
¢º Audio output with digital 5.1-channel S/PDIF and analog stereo with bilingual capability
¢º Microsoft Windows 98 SE/ME/2000/XP Operating System
¢º Easy-to-use GUI.
¡á Specifications
Section
Item
Specifications
Antenna input signal
Input frequency
57 MHz ~ 860 MHz (VSB, NTSC)
Antenna impedance
75 ohms
Connector type
IEC 169-2, female, F type (VSB)
Symbol rate
10.76 MS/s (VSB)
Demultiplexer
Stream format
MPEG-2 transport stream
Data rates
Max. 40 Mbps
PID
Controls up to 32 PID
Video
Algorithm
MPEG-2 Main Profile @ High Level (HDTV)
MPEG-2 Main Profile @ Main Level (SDTV)
Decoding format
All of ATSC digital TV standards
Display format
HD : 1920x1080i, 1280x720P, 1024x768P
SD : 704x480P, 704x480i
Audio
Mode
Dolby AC-3
A/V Input
VGA
Analog RGB input through DSUB-15
CVBS input signal
Composite Video Signal through DSUB-15
Audio input signal
Analog Stereo Signal through DSUB-15
A/V output
Video output signal
RGB or YPbPr, 1 Vpp with 75 Ohm termination
Video connector
DSUB-15
Audio output signal
Analog : 2 channels (L,R - Analog Stereo)
Digital : S/PDIF (5.1-channel AC-3)
Audio connector
3-pin header (Analog), 1 x RCA (S/PDIF)
Function
Free-to air
Yes
Multi-lingual
Yes
Select screen size
16:9 / 4:3
On screen display
Yes, 24 bpp and 8-bit Blending
Frame Buffer Memory
SDRAM
16Mbytes
PC & Software Interface
PCI bus
PCI bus Specification 2.2 Compliant
33MHz or 66MHz operation
OS
Other
DirectShow filters
¡á Main Features
¢º Easy-to-use GUI.
¡á Specifications
Section
Item
Specifications
Input frequency
Antenna impedance
75 ohms
Connector type
Symbol rate
10.76 MS/s (VSB)
Demultiplexer
Stream format
Data rates
Max. 40 Mbps
PID
Video
Algorithm
Decoding format
Display format
Audio
Mode
Dolby AC-3
A/V Input
VGA
CVBS input signal
Audio input signal
A/V output
Video output signal
Video connector
DSUB-15
Audio output signal
Audio connector
Function
Free-to air
Yes
Multi-lingual
Yes
Select screen size
16:9 / 4:3
On screen display
Frame Buffer Memory
SDRAM
16Mbytes
PCI bus
OS
Other
DirectShow filters
