Mike Loiterman
- Jan 24, 2000
Excellent entry level center channel speaker. $50.00 OBO. Shipping should be $18.00.
FREQUENCY RESPONSE: 85Hz-20kHz±3dB SENSITIVITY: 90dB @ 1watt/1meter POWER HANDLING: 75 watts maximum continuous (375 watts peak) NOMINAL IMPEDANCE: 8 ohms ENCLOSURE TYPE: Sealed TWEETER: K-88-KV 1" (2.54cm) Polymer dome HIGH FREQUENCY HORN: Dhorm HIGH FREQUENCY CROSSOVER: 2300Hz WOOFER: Two K-1016-SV 5.25" (13.34cm) Poly cones DIMENSIONS: 6.75" (17.1cm) x 20.25" (51.4cm) x 6" (15.2cm) WEIGHT: 14.5 lbs. (6.6kg) ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF) FINISHES: Matte-finish Black viny
