CraigF
Don't ask me why I want this, but I do. As far as I knew the only available version was from Criterion, but DVD Empire doesn't list it as from Criterion. Anybody know for sure? Thanks.
Nothing beats seeing severed body parts popping out of the screen in all of it's original SpaceVision gore!Yeah, the part where some guts on the end of a spear were sticking out into the audience was pretty memorable.
My understanding is that with regular interlaced TV, you can use some LCD glasses that sync to the frame rate, alternating which eye sees the frame, thus giving a simulated 3D effect. This works even better with a media specially made for 3D with the alternate frame images specially composed. These glasses with an IR link etc. can be had not too expensively, but my understanding is that it's intended for VHS/TV source. To use with a DVD, I think you need a projector, an HTPC, and a converter between the source and projector. Besides the IR/LCD glasses. As you can tell I don't know much about it, it's not that cheap, I don't have a projector...it's not in my near future. IMAX does something like this for their 3D presentations. So it's doable, but don't know how good the 3D would look on a "small" screen, I imagine you'd lose most of the effect.
I have read somewhere that Imax offers a 3D package of discs/glasses for home use. I am curious. Know anything about that (the Imax site is a pain)?In addition to the link Lew provided, you can try a search on the Slingshot 3-D DVDs using this forum's search engine, as the DVDs have been discussed here at length previously.
