John Stone
- Aug 5, 2001
I am in the planning stages of my first dedicated HT. Unfortunately my house lacks an optimally sized empty room; The best I can do is only 13'2" x 12'9".
I had originally planned to use a 57" Toshiba RPTV (57HX81), but with it I will lose over 2' of valuable space. So, after reading many of the posts on this forum, I'm now leaning towards using a front projector setup. I made a 80x45 "screen" using a bed sheet so that I could gauge the size. It doesn't look too big to me, but the Crutchfield chart says otherwise. Maybe I'm dreaming. With no image on the "screen" it is hard to tell. Is a 80x45 screen too large for the room? The seating distance is about 12' from the screen. I assume a second row of seats at 9' distance is out of the question.
Any advice on making this rather small room into a decent HT is appreciated.
My second problem is the sound. I know that my room is not ideal for perfect theater sound, but I imagine that I can still get things sounding pretty good with a little planning and advice. I'm probably going to use Klipsch speakers: RF-3/RC-3/RS-3/KSW-12. My main concern is the placement of the surrounds. I can mount them to the side walls at the back of the room (facing each other), but they will be just inches from the back wall which I've heard is a no-no. Alternatively I could mount them on the back wall, facing towards the screen. I'm open to any suggestions here as well. Thanks everyone!
http://www.twowiresthin.com
