Rick Radford
- May 12, 2001
Looking ahead to getting the BFD1124p and using it with my RS SPL meter and SVS 20-39CS, I have a few questions.
1) Should the receiver be in any particular mode? Stereo? Mains set to small or large? (normal is small) Does it matter here if the test CD is Autosounds, Stryke, or homebrew?
2) As I anticipate limited use of an RTA, I'd guess that the rampup time to figure out how to use an RTA like Spectra+ will likely exceed how long it would take to just manually note the readings (10-100 Hz individually) and create an Excel spreadsheet. True?
Plus, the next time I'd need to use it would be when the room is rearranged.. and I'd be outside the 30 trial period to boot.
3) What does Spectra+ cost anyway?
Also, to use an RTA, I'd have to get ~35 feet of cable and connectors to hook my SPL meter to the PC.
4)Are there line losses with that length of cable to consider?
All-in-all, it seems to me that a one-time use of an RTA would not be worth the effort (compared to the manual method). But, since I've never used an RTA, I may well be missing an important consideration. Whatcha think?
(however, the geek factor in me says to use the RTA regardless of how long it takes to figure it out!)
