Ian_J
- Oct 15, 2003
Two main RSF1000 and a Center RSC 300 for sale. They're in good condition but have some cosmetic damage to the caps (top of the speaker) & some stains on the grills.
Will sell for $350.00 or trade for, uh something. Let me know what you want to trade or make me an offer.
please email: [email protected]
http://www.eosone.com/htrsf1000b.htm
Must be local due to weight.
Frederick, Maryland
RSF1000
Overall Frequency Response
26Hz - 22kHz
Recommended
Amplification (8 ohm)
40W min, 175W max
Sensitivity
89dB
Subwoofer Amplifier Power
peak power 225W
continuous power 120W
Driver Complement
2 x .75" (19mm)
titanium dome tweeters
1 x 4" (100mm) midrange
2 x 6.5" (165mm) mid/woofers
2 x 10" (254mm) woofers
Enclosure Type
sealed subenclosures
for midrange, mid/woofers
bass reflex for powered woofers
Crossover Frequencies
front elements: 850Hz, 5.2 kHz
rear elements: 5kHz
powered woofers: adjustable,
50-100Hz
Nominal Impedance
compatible with 8ohm amplifiers
Dimensions (h x w x d)
49"H x 13"W x 18.8"D
124.5cm H x 33cm W x 47.8cm D
Weight
116lbs
Frederick, Maryland
RSF1000
26Hz - 22kHz
Recommended
40W min, 175W max
Sensitivity
89dB
peak power 225W
Driver Complement
2 x .75" (19mm)
Enclosure Type
rear elements: 5kHz
50-100Hz
Nominal Impedance
Weight
116lbs
