Chris Eriksen
- Aug 10, 1999
Hello Everyone,
I am hoping you can help me with a DIY sub enclosure for my home theater. I have a lot of experience designing and building exotic sub enclosures for car audio, so the fabrication will not be a problem. However, car audio applications rely heavily on cabin gain, so my design plans may be a bit suspect. Any recommendations will be greatly appreciated.
I already have the driver and the amp, as well as a Behringer Feedback Destroyer. The sub amp is a Hafler 9290, which produces approximately 500 watts rms into a single 4 ohm load. The sub is a Cerwin Vega XL-18S, a high-efficiency lightweight paper-cone driver that was originally aimed at the car audio market. Here are the T-S parameters on this 18" sub:
Imp. 3.5l
Fs 28
Qes 0.173
Qms 5.249
Qts 0.167
Vas 7.31 cu ft
Xmax 0.33"
PE 500 watts rms
SPL 96 dB @ 1w/1m
My oddly-shaped HT room is on the large size, with a length of 27', a ceiling height of 11', and a width of 10-15', depending on the location. A drawing of the room is located HERE . Please ignore the speaker locations, as these have changed. The primary seating area has now been moved back to a line that extends between the green blocks.
My design goals are as follows: Deep bass extension and good transient response (for an 18" sub) in an enclosure of less than 6 cubic feet. This sub will be used for HT only, as my mains have a useable in-room response to below 40 Hz.
Here is where I become uncertian. From my preliminary calculations, I am considering a 5.3 cubic foot vented enclosure, tuned to 18 Hz. Should this enclosure yield my desired results? Or am I barking up the wrong tree? Please let me know if I am overlooking something, or if anyone has suggestions for a better design.
Thank you in advance,
Chris Eriksen
Imp. 3.5l
Fs 28
Qes 0.173
Qms 5.249
Qts 0.167
Vas 7.31 cu ft
Xmax 0.33"
PE 500 watts rms
SPL 96 dB @ 1w/1m
Chris Eriksen
