Kyle Richardson
- Jan 1, 1998
Jeff's recommendation of the PE vinyl laminate is a good one. If you want to save even more money just paint the MDF. If you do make sure you prime it well especially on the end cuts because it will really soak it up. You can spray the paint on for a smooth finish or I've had really good results using a roller with a fine nap for a bit of texture. It all depends on the finish you are after.
