MichaelO
- Mar 29, 2000
Hello there. Got a quick a question concerning dts setup.
I am using a Panasonic RV-80 DVD player and it has a dts decoder built in. I have PCM selected for dts in the players setup menu so that I can use it as my dts decoder, my pre/pro has 5.1 inputs to take advantage of an outboard processor.
Anyway, I have been using it for a while now with no problems. However, I read that dts needs a 10dB LFE boost that DD doesn't. Should I set my processor up so that the sub is 10dB's louder when playing a dts movie than a DD one? The players setup menu allows you to adjust channel levels but the max addition you can add to the sub is +6. So I can adjust another +4 over the DD setting through my pre/pro. Is this correct?
Basically I am using my pre/pro to decode DD tracks and have calibrated DD so that my sub level on my pre/pro is set to 0 which is actually +8dB over the other channels at reference. (I prefer a little more oomph from the sub so I increased it by 8dB). Now for dts I have the sub at a +6 via the DVD players channel setup menu and an additional setting of +4 within my pre/pro, a total of 10dB increase over the DD settings. Does this sound right or have I just completely confused everyone here?
Just trying to compensate since neither the player or my pre/pro offers a dts LFE boost. Was hoping that the LFE boost/gain? would be the same as increasing the sub level.
If someone can clear this up for me I would certainly appreciate it.
Michael
Michael
