drobbins
- Dec 2, 2004
- Dave
I am in the process of putting a theater in my new basement with 9' walls. On the left hand side there is a HVAC duct that is about 10" in height and the entrance way into the theater. To the right of the HVAC duct, is the main seating for the theater. The I understand how to install a drop ceiling, but I would like this one to be 2 different heights. Under the duct to the door will be 8', but to the right of the duct, I would like it as close to the 9' as possible. This will allow for the screen to be mounted higher. The question is: how to do the vertical side of the HVAC duct between the different heights? I don't want to build a small wall hanging down because it would be too thick. I was thinking of using plywood, but would it warp and how would the bottom look? Anyone else run into this?
Dave
Dave
