rich r
- Jul 29, 2001
I am interested in building a DIY microphone using speakerbuilder.net's design and the panasonic mic cartridges. -=-My concern is a wand!!-=-
What would be the ideal wand that could be made. My father is a tool & die maker so fabricating a wand out of steel or aluminum would not pose a problem.
My questions are:
1. what material would be best to use??
2. should the mike cartridge be recessed and flush mounted into the wand and secured with an adhesive such as epoxy??
3. What type of hook up wire would be recommended to achieve the cleanest signal?
4. what would be an ideal length for the wand to be??
If anyone has pics or info that would be useful it will be much appreciated
My questions are:
