mackie
- Feb 7, 2004
There are several advantages to having a separate power supply.
Separate amplifiers can usually put out more power for a longer period of time before they start clipping or shut down. This is due to a more robust power supply and more heat sinking/cooling.
Because of the power supply they can drive more difficult loads easier. Speakers are pretty complicated in that they aren't they have different Ohm levels at different frequencies. A speaker may be 4 ohm at 40 hz, 8 ohm at 350hz, 16 ohm at 1500hz... For lack of more technical terms, the separate amplifier's power supply can tolerate this better than a low quality power supply. Your mid-level receiver should be able to do this also except in extreme cases.
Other advantages, better THD, better slew rate(recovery time), and external amplifiers last a long, long time. It also helps with future upgrades, and it gives peace of mind knowing you've got enough power no matter what you decide to do....
Separating the power supply from the processing parts also removes a potential source of interference and the heat generated by the amplifier isn't good for the micro-processors.
A good mid-level receiver try to have the best of both worlds. Enough power to drive most speakers under most circumstances and have all the bells and whistles.
I suspect there are engineers out there that can elaborate more on this and maybe correct a few things here. But this my understanding as a hobbyist of how this works.
Upgrading to separates is a good step to take. But I wouldn't spend money on a separate amplifier until after I have speakers I want to live with for a long time and I've addressed the room's interaction with my system. Some people note remarkable improvements when adding desperate amplifiers, but I didn't. Looking back and knowing what I know now, I could've spent my money better. BTW, I've kept them amps I've bought because they give me more setup options and will be useful in the future. I don't feel I wasted money, but I could've put the money towards another sub, room treatments, video scaler...
