David*RT
- Jun 26, 2002
I have a Denon 5800 being relegated to preamp duties. I have a separate amp.
Is the Denon preamp audiophile quaility or should I go with a separate preamp w/ remote & HT out jack (around $1000 budget) to run my mains while the Denon does the other HT speakers.
The sonic difference has to be marked over the Denon for me to consider spending additional $$$ for a preamp, otherwise it wouldn't be worth it.
If you guys advise for the preamp, can you list potential candidates?
Thanks in advance................
