Kevin. W
- Oct 27, 1999
I have a Rotel RMB-1066 AMP hooked upto my Denon1801. When I put the AMP in signal sense mode while watching the movie it will turn itself off and on for no reason. I noticed in the manual for the AMP that the input sensitivity is 1.5v and the Auto turn on Threshold if activated is 10 mV input signal. The Pre-Out of the Denon is rated at 1.2V with an Input Sensitivity of 200mV. I have contacted Rotel and was told if the input signal is not strong enough it would shut off after a perid of time. I was told to use the 12V trigger. What is a 12V trigger?
Kevin
Kevin
