Daniel Swartz
- Mar 3, 2002
Rhino sells three types of component cables: standard, performance, and premium. The most notable difference is that standard uses Belden 1694a cable while performance and premium use Belden 1695a cable. All three lines use Canare 75 ohm connectors.
My use for the cable will be HDTV and progressive DVD capabilities. As far as I can tell, all three are overkill in terms of sheer bandwidth. So, what makes performance better than standard and what makes premium better than both standard and performance lines?
I'm cross-posting this over at AVS... Thanks guys.
Standard Specs
Performance Specs
Premium Specs
Standard Specs
Performance Specs
Premium Specs
