Salvador
- Dec 4, 2001
Would it be possible to connect my soundcard using a minijack to stereo cable to an amp like an oddysey stratos or parasound?
Sure, you can pick up an adapter from Radio Shack or any other electronics/computer store whick will convert mini-jack to RCA phono. Adding a sub could be tricky if your card does not already have a pre-out for one.
Your proposal about hooking up the card to a power-amp is certainly doable. I guess you have to ask yourself if you ever want to do a full surround set-up or you plan on using more then one source for your system (you would need a receiver or another audio switcher).
Truth be told, the performance you would get from your receivers D/A converters or an external CD player should give you much better performance then what your sound card can do. If you are serious about 2 channel music, then a computer would not be my source of choice.
