phill clarke
- Mar 19, 2002
I've got a small cabling issue with my 27" tv, Panasonic CT-27D21. The unit has 1 component and 1 s-video which are switchable, meaning one works or the other works. I've been using component from the DVD player but I'm moving to a new location where I'll be using DirectTV. The DirecTV is not HD format since I can't afford it currently. The DirecTV unit has a S-Video out which I'd like to use, but this is where the problem is. I do have the ability to do s-video switching through my receiver, but not component. So here's where I need the help...
Do I ditch the component DVD solution and run all S-Video through the receiver switching?
Would there be a noticeable difference on this since I only have a 27" TV?
Should I keep the DVD on component and just run the DirecTV through standard video cables(composite?)
Does DirecTV really gain anything by running S-Video?
Sorry if this was a little long...
I appreciate any help with this
Phill Clarke
Phill Clarke
