arunVB
- Jun 16, 2005
I am planning to buy a pair of 7001sc for my front speakers. I am getting a new CLR 3000 for the center. I checked with my local authorized dealer. He said they stopped carrying the 7001sc (they carry the 7000sc and 7002) and but can one that was on display, that might be less than 6 months old, for around $1300 each (They used to sell the new ones for $1750 each). He says that they will be in good condition and not even played everyday.
Assuming there are no visible damages and it seems to work properly, is it a good idea to go this route or will I be better off getting the new ones ?
If it is OK to get the display models from the dealer, what and how should I check to make sure the speaker are functioning properly ?
Any help is greatly appreciated.
Arun
Arun
