Coreena
- Jul 18, 2002
We recently purchased a Bose Lifestyle 35 system. The sound is great and we are very impressed with the redistribution of sound from non-5.1 sources, but we have one problem that is significant enough for us to consider getting rid of the system.
On the DVD player, many movies display the subtitles and cannot be turned off. This even occurs on movies that do not have a subtitle option. I contacted Bose and was told that this was simply the result of faulty programming on the DVDs themselves, but it should not happen too often. The rep also said that as far as he knew, they were not working on a software patch for the problem.
The majority of our movie collection is DVD and when I tested a dozen or so at random, I found that almost half had this problem. Has anyone else experienced this problem? Do you know a way around it? Help! We're at our wit's end.
Coreena
Coreena
