Patrick_M
- Dec 3, 1999
I have recently installed this card on my system, and I was wondering what is the best software to use to video capture tv shows? What I want to do is record tv shows and then put them on vcd or svcd. Is the software that came with the card the best option? And if it is, what are the best settings...I tried a "medium" quality setting for SVCD and recorded the thin man off of tcm the other night. My file wound up over 8 gigs! So if anyone has come up with any custom settings to maximize quality while fitting a one hour show on one svcd, I sure would appreciate. Thanks.
