Kevin Beck
- Jan 4, 2001
Well,.. not sure what I will end up doing, but I may build new enclosures for the Tempests. Theater is in the basement, 15 X 20 room, 7ft. plus ceiling. More than likely, will be feeding them quite a bit of power,..over the 250 normally used. Any experienced oppinions. The Sono I have doesn't sound like its going to work out. A little more testing, but it doen't seem to have the output it should.
Thanks >>>--->
Thanks >>>--->
