Banna plugs bottoming out. (1 Viewer)
Jason Bell
Probably a stupid question but here goes. I've got some M-series monster cables with Bannana plugs at the ends. When I plug these into the 5-Way posts of my Axiom Speakers they dont insert completely flush they bottom out about a quarter inch too soon. Is this normal? The other end of the cable with identical plugs fits all the way into my receiver. I have the binding posts tightened all the way down are some binding posts just shallower than others?
Ned
Yes some are shallower. You're fine as long as the plugs fit snuggly
Aasim
