KeithH
- Mar 28, 2000
I don't like to leave discs from box sets or digipaks in the original packages because the packages either don't fit on my shelves or they wear out from constant handling. As a result, I like to put the discs in jewel cases. The problem is that I don't have front or back inserts that I can put in the jewel cases. Are empty jewel cases available that have blank inserts? I would just label the inserts by hand so that I could easily see which disc is which on my shelves. All the empty jewel cases I see in stores come without inserts. I guess they assume you are going to use them to replace jewel cases for pre-recorded CDs that already have inserts. :frowning:
Thanks in advance.
Thanks in advance.
