Michael Langdon
- Aug 29, 1998
Just got the manual for the Aragon Stage One (MSRP $4000). I have it in PDF format. Maybe someone can put it somewhere for others to download. I will e-mail it to those interested. The manual is being revised at this time but only for the tuner section.
Highlights:
24 bit Crystal digital to analog converters
Motorola DSP (not in manual; info from rep)
3 toslink, 7 coax digital inputs
THX Ultra 2 (and corresponding modes)
Dolby Digital 5.1
Dolby Prologic II
THX Surround EX
DTS ES Matrix and Discrete
DTS NEO 6
Bass Management: 25-120 Hz in 5 Hz increments (applied globally)
Separate bass management settings with different crossover for stereo listening versus all other modes!
Separate level adjustments are available for each mode!
Speaker distances for delay is to nearest inch or 1/12th of a millisecond (i.e 03'00")
Speakers levels are set to 0.5 db increments
Individual volume settings are saved for each source
ProntoNeo remote included
Dislikes:
No bass management on external multi-channel inputs (bypasses DSP)
External multi-channel input is via DB-25 connector (need RCA to DB-25 adapter)
What do you think?
Mike
Highlights:
Dolby Digital 5.1
Dolby Prologic II
THX Surround EX
DTS NEO 6
Dislikes:
What do you think?
Mike
