Philip_G
- Nov 13, 2000
Yes, it goes to the used oil tank in the sky. I take mine to checkers and they accept it just the same
Peter A asked a very good question about why you can't break in an engine with synthetic oil. The answer is that there needs to be a polishing effect on the rings and cylinders and valves etc. to level out the microscopic peaks and valleys on the parts. Synthetic oil is just too slippery to use on a brand new engine, thus the parts don't seal optimally. I guess this is why most manufacturers have the short mileage on the break in oil. Cars that come from the factory with engines already filled with synthetic oil are probably broken in on the bench before installation. Maybe a member who works at the factory can fill us in on this.
You would think that they would break them in on the bench first but in some case, that would be a lot of engines!
Also if you use synthetic don't be surprised if you get a small amount of seepage over time. Since synthetic oil is a lot more fine than normal oil, it can get in places normal oil can't. I'm not talking a huge leak or anything, it's definitely nothing to be worried about.
Changing the oil every 12,000 miles? That seems pretty extreme but if that's what the car manufacturer requires then i'd be ok with it.
Yes, that's what's recommended by BMW and that's what they cover in their maintenance warranty. We've had the car for a little over 3 years and the oil's been changed 3 times. It's nice to not have to worry about getting the oil changed every 3 months.
