Todd Hochard
- Jan 24, 1999
It is just a long ass rod and the angle is pretty wacked.Actually, the longer the rod, the better. It's the shorter rods, combined with long strokes, that get you into trouble. To use your 305 example- going .030" over and stuffing a 400 crank (3.75" stroke) into the 305 (normally a 3.48" stroke- the same as a 350), will give you around 331cu in (from memory- I might be off). The engine would live longer, and rev better, if you went up from the stock 400 5.565" rods, to the 5.7" rods (from a 350) or, better yet, to 6.0" rods. The max rod angle(when the crank is perpendicular to the bore) is reduced by the longer rod. Also, the increased dwell time of the piston at TDC with the longer rod builds peak cylinder pressure better, actually creating a bit more horsepower. The trouble with using really long rods is interfering with the bottom of the bore, and finding the right pistons with high piston pin points.
But, that's what you meant.
The object of my next engine will be to concentrate on lightening the reciprocating mass. The engine will rev faster, and that gives it a more snappy/explosive feel. Plus, higher RPM capability. It may end up in my Z28 (see my web page), if I can't find the $$$/time for the Cobra.
Todd
