- Apr 23, 2000
- Alfer
My wife in her quest to keep the oven clean while cooking pizza, put a piece of Reynolds Wrap on the ovens floor under the heating element..
Unfortunately some of it stuck to to about a 3" section of it. We tried to gently peel/scrape it off and most of it has come off, but there are still some reminents.
When it first happened I noticed that the section that had the stuff stuck to it was heating up a brighter orange than the rest of the element. That's when I shut off everything until it cooled and and began scraping and cleaning..now I don't see such a bright orange section glowing anymore. It all looks about even colored..however little pieces are still stuck to the element.
Should I be concerned or just let it be.
Curious though, is there a simpler way to take the foil off othre than what we used: SOS pad (gently rubbed off most foil) and a small knife we scraped the big stuff off with.
Thanks for any thoughts you may have.
Alfer
Alfer
