GrahamJW
- Sep 15, 2003
Hi:
I finally got a hold of the manual for my 3 year old Sony STR-DE835 receiver. I recently purchased a Paradigm PW2200 sub, so I hooked it up using an RCA cable for the sub out jack on the receiver to one of the Low Level inputs labeled “LFEin/Sub-in. My concern was bass management and setting of the other speakers. I have read in this forum were some people set their speakers to large or small (or a combinations), and if you set your speakers to small you should pin your subs cross over to the highest level, so that it doesn’t interfere with the receivers’ cross over. In the receiver manual it recommends keeping all of the speakers set to large (even if using smaller book shelf speakers) and setting the subs crossover to the highest point.
From what I can gather from the forum, you should only set the crossover to the highest point if you set the rest of the speakers to small, and if your speakers are set to large than you set the subs crossover. Am I correct in assuming that the receiver cross over is effective on speakers set to large and the sub cross over is effective on speakers set to large (this seems to be the opposite case in the receivers manual). Am I right out to lunch on this on. Does the LFE input on the sub bypass the subwoofers internal crossover?
I believe that the cross over is fixed on the receiver as I can’t set the cross over on any of the speakers that are set to small. The only problem is that I don’t know what that cross over point is.
My mains and rears are Boston Acoustics A70T (frequency response 45-20,000 Hz), and my center channel is a Paradigm CC-70.
Cheers..John
Cheers..John
