Need help installing Mission M73 speakers! (1 Viewer)
JoeScho
Joe
Hi all,I've recently purchased a pair of mission m73 speakers but am having some trouble installing them. These are the speakers:
The problem is wiring the amp at the back. Can anyone tell me what make/model it is?
Any help would be greatly appreciated!Joe
schan1269
HTF Expert
Chicago-ish/NW Indiana
Sam
The speakers you have are "meant" for bi-wire/amp.However, use a short piece of wire connecting red to red, black to black. Then connect the amp to one set.That amp, no clue. Can you remove it from the mount?(Is that mounted in a van?)
papill6n
