I've recently bought a Pioneer HTP-072 home cinema package which includes the Pioneer VSX-324 AV receiver. I'm pretty happy with it but I need to improve the sound a bit. And I need some advice on how to do that. I've set the speaker distance and I've tried setting up different speaker levels but I don't have a proper SPL meter to test everything so I've used a basic smartphone app. I've modified the levels a bit so that they were all showing the same level for the test sound.
I've watched two 5.1 channel movies and a few stereo ones to test everything out. First one is the six channel one. Sorround was great but the actual speech on some quieter scenes was almost unrecognizable. I've increased the center level a bit and it's better now but it's still not great - speech is still too quiet for my liking while the other effects are pretty loud.
Of course my speaker position could possibly be somewhat of an issue here. The front speakers are almost 4m away from my sitting position while sorround speakers are less than a m.
On the other hand I still find the sorround speakers a bit too quiet but only on some scenes so I am not sure if it is designed that way or not.
Now for the stereo. Extended stereo is fine. But I did try Dolby Pro Logic 2 as well. And I am not entirely sure that I like it. If I turn that on then I lose a lot of base and the sorround speakers are too quiet except when you have some strong effects or music playing which is a problem when you are looking at a drama movie where you practically don't have much of this. Rear speakers are almost silent in that case. And I am again not sure if it's supposed to be that way or not. But when compared to 5.1 encoded video I find the speech perfectly ok.
Any advice?
Any advice?
