Help with Input (1 Viewer)
solid102
Muntasar
Greetings everyone as this is my first post in this forums. I got one presice qustion regarding a purchase. I bought a Panasonic SC-HT640W which can be looked at by this link:
http://www2.panasonic.com/webapp/wcs...00000000005702
Now its a nice system for the buck but I got a problem since it got only one audio input which i can connect my cable reciever to it but my problem is i want to connect my ps2 to it too so a second audio input would have been nice. I been thinking as I used to see types of adaptors that allowed you to connect mutliple A/V wires to it then its comes out with one wire and connects it to your DVD/Reciever i tried searching for such device but i cant seem to find it here in the USA.
Any helps/tips will be greatly appreciated, take care of your self and each on.
Seth=L
Seth L
Radioshack has stereo audio switchers that can switch between sources. I personally have a Component, Composite, S-Video and stereo audio switcher that can switch between 4 sources. I got it at Wal-mart for about $20 which is about the same as if you bought an audio only switcher from Radioshack, and you never know when you will need that extra video switching.
papill6n
