Help hooking up a Mac Mini to HDTV (1 Viewer)
Joe Doyle
I have tried everything to get my Mac Mini to display on my HDTV through a DVI connection. I have used SwitchResX and DisplayConfig to get it to display. I have ran VNC on the Mini and connected with another computer but the Mac Mini show no monitor being connected even when the DVI cable is ran to my TV.
I tried the AverMedia Quickplay to go Mac Mini with DVI to VGA Adapter into the Quickplay to Component Video on my Tv and that didn't work.
I know the DVI port on the TV works because I have a DVD player hooked into it, I know the DVI port on the Mac Mini works cause Ive hooked it up to a monitor with a DVI connection.
Any suggestions?
Rommel_L
The DVI input could one of many inputs on the TV. Have you selected the right input to display on the TV? For example, input1 would be s-video, input2 is component, etc.
bmoore9
