john berry
- Nov 18, 2002
Hi, I am hoping someone out there can help. Spent all day today trying to set up a new HT setup in our family room and still having problems. I should note I am no novice - I set up a sweet system in our basement about 10 years ago (Pioneer Bug Screen TV, Definitive Technology Speakers, Yamaha Receiver, LD, DVD, CD etc). However, technology has changed andeven though I did research, some things were stumping me today with our Fam Room setup (note this is not as bog time as my existing basement setup - less intrusive to satisfy the wife).
The Components:
My old 27 Sony TV. This baby is around 15 years old - so it just has component inputs - no S-video, etc
A new (refurbished) Denon 1803.
A new set of Wharfedale 60+ moviestar speakers (5+1) (Sub is powered).
An old VCR
Old Sony 100 disc CD player
An old Sonance 260x3 amp (this is used to pump music independently to 3 other rooms in the house)
a new JVC XVN50BK DVDmy daughters old X-Box
My problems:
1. biggest problem is the hum in the speakers. This is my first time using a subwoofer (didn't need one for my basement setup) and it is humming bad. Additionally, when I go to listen to the DVD or X-Box thru the system - also get bigtime hum thru the Center speaker as well as most of the surround speakers. (note hum may be on other speakers all the time - but I may not have heard on Tuner playing it loudly - can't retry now - everyone else is asleep)
2. Had a problem with no picture on the DVD - but think I just figured that one out
3. unsure about how best to handle x-box connection
My Connections:
1. Speaker connections straightforward - separate line for sub- connected from single line out on receiver using Radio Shack Digital Audio cable / Monster Y connector to sub.
2. VCR connected thru Component cables to Denon. Also, Cable company COAX first connected to VCR then to TV.
3. X-Box connecnted thru component cables to Denon
4. CD Player connected via component cable to Denon
5. Denon connected to TV via component cable
6. DVD - connected via Optical Toslink to JVC DVD. I also had a S-Video connect to JVC - but had no picture. My guess is that since my Receiver is connected to TV only by component cable, the S-vdieo signal did not get passed on. So I disconnected it, and hooked the DVD viceo out componenta cable between the TV itself and the JVC DVD - and picture works fine. I thus assume there is no need to route the DVD video thru the Denon - correct???
7. Sonance Line in to Denon Tape / CD Line out connection via component cables. This seems to be working fine.
8. X-Box xurrently hooked to Video-Aux connection of Denon via component cables - seems to work ok - except for speaker hum. but is this best for my 10 year old to deal with? Should I skip the Denon and just hook the X-Box back to the TV?
Any help you can provide would be greatly appreciated. Especially with this darn speaker hum - not only from the sub, but also from the Center speaker and the surrounds (not as noticeable). All the speakers are supposedly shielded. Right now my family room looks like a disaster area - all the old equipment, boxes, packing mat'l, etc - and it still ain't working right. Given the Denon is refurbished - I wondered if that was a problem with the speaker hum, but I doubt it.
frustrated and tired now
The Components:
An old VCR
My problems:
My Connections:
