Looking for a Digital Menu system on LCD (1 Viewer)
John510
Not sure if I am in the right place but I have been looking for a digital menu system for my pizza restaurant. I would like the menu to be displayed on TVs and I want to be able to control the menu pricing and specials from the office. Can someone direct me in the right area?
John from CA
Jason Charlton
Baltimore, MD
Jason Charlton
I'm not sure if there's a commercially available product out there that does that sort of thing, but it could be developed custom for you using any number of programming languages. An application developed using Flash/AIR could easily accomplish this sort of thing.
You could try searching/posting to various job boards in your area - look for web/multimedia developers and designers with expertise in Flash and/or AIR (just about any programming language could be used, but there seem to be many Flash developers out there, and not only would the cost likely be less than a C++ programmer, but you have a better chance of finding someone with some design expertise that will help make the application LOOK good).
Joseph DeMartino
Florida
Joseph DeMartino
In this case the display device (whether a TV or computer monitor) is secondary to the source, which would clearly be computer based. You might want to contact a moderator and have the thread moved to the "Computers & HTPC" section of the forum.
In the meantime, here's one of many links I found after doing a Google search for "restaurant menu display system"
IDS Menus - Inside Menu Board
Joe
Nielmb
