Max Leung
- Sep 6, 2000
Jeff, be sure to get the rebel with the bundled 18-55mm EF-S lens (aka kit lens). It's only $100! It's not a bad lens when you stop it down to F8 (its sweet spot for sharpness). You'll need it for the wide-angle anyways - compare $100 for the bundled zoom lens to the $400+ for a 20mm prime (no zoom) wide-angle lens. Get the kit lens!
I'd recommend the Canon 50mm/F1.8 mkII lens ($70 US or so)...fantastic for portraits and low-light. Can't zoom though. The Canon 28-135/F3.5-5.6 IS is great too! If you want more reach (who doesn't?) some people suggest the Canon 75-300 IS USM lens ($400) or the non-IS but cheaper Sigma 70-300 APO Super II ($200 US).
Just remember that there is a 1.6x factor when you mount any lens on the Rebel.
Also, keep in mind the flash underexposure issue. The camera uses the E-TTL system for determining exposure, and it can be tricky. Here's a good introduction on E-TTL metering and flash: http://eosseries.ifrance.com/eosseri...ork_intro.html
For batteries, you should be able to get a BP-511 "clone" for around $20 US. I bought mine from eBay. Only issue I had is that it doesn't fit snugly in the charger...a bit loose! But still worked.
Quick summary of issues with the EOS 300D (aka Digital Rebel):
Flash tends to underexpose if you just point-and-shoot.
No second-curtain sync with flash, unless you get a higher-end flash with manual abilities like the Canon 550EX or Sigma 500 Super DG.
Depth of field is very shallow, so objects further away from the focus point may be out of focus. As a rule of thumb, try to stop down to F8 on the kit lens. This will be different for other lenses of course. A shallow DOF is great for portraits however...you can easily blur the background! Just make sure to think carefully before pressing the shutter.
Auto white balance isn't the best...my G3 could guess the white balance better than the Rebel. Get a gray card and use custom white balance instead, if color accuracy matters to you.
Lenses add weight! Your wife may not like the weight of the camera when you slap on different lenses. The Canon 28-135 IS weights about a pound.
Have fun!
Have fun!
