Folks,
I see there is a major difference in bench test between RX-A2040 & RX-A2050 when using 5 channels simultaneously :
https://www.soundandvision.com/conte...iew-test-bench
Does it mean RX-A2050 has a major power improvement, or RX-A2040 test result was wrong ?
I think Yamaha makes power output of RX-A20XX series the same, (ie : RX-A2040, RX-A2050, RX-A2060, RX-A2070) ?
Is this assumption right / wrong ?
Anyone knows bench test result of RX-A2060 ? I am about to use RX-A2060 with 5.1 set-up :
* Front : Monitor Audio Bronze 6 (rated 150W)
* Center : Monitor Bronze center (rated 120W)
* Rear : Monitor Audio Bronze 2 (rated 100W)
* Sub : 100 watts
Is RX-A2060 is good for above set up or must I use external Emotiva (2 ch) to feed the front Bronze 6 ?
(for I don't want to have clipping or distortion).
Really appreciate for all advise.
* Sub : 100 watts
