Martin Fontaine
- Aug 15, 2001
Now, when I boot, sometimes the WAV file that plays at logon skips! Then when all programs load (Stuff like Seti, E-Mail, ICQ, StopZilla, Webshots) it takes noticably longer than before.
The only 2 things that I remember doing that COULD have caused this are:
1. Added a 27 Gig HD which was my old HD before I got the 60 Gigs I'm using now. I reformatted it as 1 partion (NTFS) It used to have my old installation/programs before I got the 60 Gigs and copied things over. At that time (Last April) I had strange problems with my PWS (Which I replaced) and having 2 HDDs sometimes caused the PWS to refuse starting up. Now that I have a new PWS (Replaced in June if I can rememeber) I could put the 27 Gigs back in, I just didn't get around to it until last week.
1.1. I removed a ATI TV Tuner card at the same time as I put the 27 Gigs in since it is not recognized under XP (Was appearing as "Other Device" with a yellow "?" in Device Manager) I posted a thread acking for a replacement. I doubt Windows is "looking" for it since it is no longer mentionned at all in Device Manager.
2. Converted my first 2 partitions (4 and 2 Gigs respectively) to NTFS. I backed up the files to the 27 Gigs before just in case.
Windows seems way slower ever since that. Is there something wrong with my setup? Isn't NTFS supposed to be faster than FAT32?
Another weird oddity is that earlier today, it got stuck on the POST and I needed to power down, wait 15 secs and power on again to boot and then Primary HDD Fail!!! WTF! Rebooted again and my CMOS settings were gone, reconfigured them and now the HDD was back!
So I went on Gigabyte's website to download a more recent BIOS and flashed my BIOS (With all the mouse jerkyness and strange thing, could be a corrupted BIOS) Then Windows XP won't boot! Not even in Safe mode!
I put the Win XP in the CD and booted with it, did a repair install. It seems to work fine now but the slowness in booting is still there and sometimes it takes kinda long just to start or close Folder or Browser windows.
Thinking it might be HD Fragmentation, I defraged many times in the last week or so (Since the FS convert) and it only seems to make it worst!
What should I do? Are the CMOS/Boot problems just coincidence/one time only glitches or is my MoBo faulty and need to be replaced? Is there some special tweak I should do in XP (I'm using Pro) or should I reinstall it from scratch (Formatting the C: and D: drives properly into NFTS not FAT32 converts)
