I just have a quick little question. A newb question of sorts. I really am wanting to build a sealed shiva using adire's 54L design. And I eventually am wanting to make five speakers to go with it. But I will do the sub first. It will be my first DIY project. However right now I a have a most craptastic Sharp HTIB which is just dolby Pro-logic. Should I replace the receiver first and then do the sub or do the sub then the receiver.
My ideas/options I am trying to decide between are
1. Build sub run it off of the sub output of existing receiver with speaker line out (that's all it has for sub) and power sub off that receiver. Then save a while get plate amp use high input on amp. Then buy new receiver.
2. Wait a little longer and save to buy both sub parts and plate amp. and run off of the receiver speaker line for sub. Then save and get receiver.
3. Wait even longer and buy parts for sub, plate amp, and receiver. and use all together.
4. Buy new receiver save for speaker diy later.
5. Build sub...save a little and build center channel save a little while build front speakers...save a little...build surround...save a little then buy plate amp...save a little then buy receiver.
Any and all suggestions much appreciated.
If it helps I use my HT for all tv viewing and movies. I listen to music a lot but if you count in regular tv viewing also then it would be 80-20 ht to music. if you just count movies then it would be 50-50. I really don't have great ears. I know what sounds good and am really tired of my crappy system so small upgrades may sound tremendous to me.
Thanks for you time.
Larry
Larry
